More power out of a 1.5 gl
(In Topic #156748)
i was wondering if there was any way to get a lil more power out of it not looking for massive gains as will be droping a new lump in it once it looks the way i want just a bit more poke off the lights you know lol
Depending on your budget..
Exhaust and air flow is a good start..
The 1500 is a good engine if you went into it rather than a swap…the head is ripe for porting and bigger valves, and the compression is low so will respond well to an increase.
Decent exhaust's work well…try and get one now that will suit your final conversion…it may not be ideal for this engine but not alot of point in buying twice.
www.jmrclubsport.com
I think weber still do a replacement carb.
A tubular manifold helps but most available are a bit to big a bore size for a std engine…tho would help pave the way for future mods.
The decent power would come from a ported head and compression ratio increase.
You require the Weber 36TLP
Direct replacement to your solex 1B3
Best wishes
