Mk1 Golf Ignition Light on at 140K - Alternator?
(In Topic #126282)
New here.
I have maintained my daughter's 1982 Mk1 1.5GL Golf for 14 years. I know more about economy carbs and how they work than you could possibly imagine, but as result it finally runs great at 140K miles. It does about 1K per year :-)
I have noted over the last few years the ignition light seems less and less willing to go out when the engine is started.
She finally ended up with a flat battery and the ignition light is on all the time. The fan belt is fine and tight.
Just off to take a look myself and retrieve the battery to charge it back here.
Is this likely to be the alternator, or what else should I check? :dontknow:
Cattman
Skype Catthouse (send IM initially)
paul_c said
Probably just the regulator/brushes. Its easily replaceable (without removing the alternator from the car) and costs about £9.65.
I have looked everywhere on Google, can't find where to buy them, if indeed its still possoible. G+S don't do them either.?????
Any suggestions?
Thanks,
Cattman
paul_c said
They're freely available, I bought one online from GSF only last week! Go on their website, enter Mk1 Golf, go to starting & charging then look through the list and scroll down to voltage regulator.
Thanks for the steer. Was looking in wrong category, why it just can't be electrical I have no idea?
I actually called GSF before posting and the guy said they didn't have any and didn't stock them any more……..
Will try again with part number now I have it.
Cattman
Got the new regulator but it didn't fix it. Ammeter says current is actually flowing out of batterys when engione is idling, so althought alternator raises system voltage a bit it can't deliver muc curent, so the smell of hot electrics was probaly the windings.cattman said
Now need a s/h alternator, Bosch 45A 0120 489 986…… any suggestions? Tried Crazy Quiff and am awaiting answer, VA offered one new at £89.
Cattman
~Madferret
Mk1 1457cc 5door GX '83
Interesting job as it was in a car park at the roadside and I fogot my Haynes. The bottom bracket bolt with its captive welded nut the only accessible fixing visible was a puzzle!
Fortunately I had taken the cam belt cover off before and guessed the bottom bolt had a similar sized Allen Key head to the lower cam belt top cover retaing nut - once I realised the head of the bottom securing bolt was round and the back side of the cam belt housing had to have an access hole in it.
What a fiddle! Thanks Helmut.
quote="Madferret"]You did check the wire and connector 1st didn't you? :wink: they've been known to corrode from time to time…
Cattman
query ...
Hi people,
whats really involved in making my Golf Mk 1 diesel motor into a turbo diesel ?
need all the info ,plz .
i'm in Adelaide,in AUSTRALIA !
HELP !!!
What has this got to do with my alternator problem please?sooty12321 said
Hi people,
HELP !!!
PS The answer is buying a turbo diesel engine from a breakers. Better still a Golf TDI, not dicking with something designed as an integrated unit and invalidating its safety homologation and insurance, I think.
Cattman
i thought i'd selected a new topic.
Profuse apologies,boys.
