Mk1 Cabby 1.5 engine water leak - help wanted
(In Topic #135072)
When I filled the radiator before starting the car, I spotted the water running straight out (engine not running so no pressure in system). I put car up onto ramps and could see water running down from behind the sump central, in the starter motor area. With the engine running the water pumps more quickly.
All the hoses that I could see from the front / underside looked and felt ok. and I can't see anything obvious from above.
Previously (before the carb work was done) the car used to use up a little water - not excessive but advisable to keep a can of water in the car 'just in case'. Needed topping up every couple of weeks or so.
The engine sounds fine - doesn't sound as if anything has blown.
Can anyone suggest what/where the problem might be? Thanks.
i have a sweet running 1.5 engine handy as a spare.
I would suggest using one and closely inspecting every single pipe you see slowly.
Some pipes have never been removed in the car's lifetime , problem is limescale builds on the pipes, all this needs to be cleaned, water flsuhed in and out fo every pipe to clean system.
It could be a coreplug, what i did not like was you stating you've been topping up the water before, this would suggesst "maybe" head or core plug".
Again this can be caused as mentioned using no anti freeze etc a some just think all the need to do is turn the key lol.
The car should not be using any water atall.
On this one comes down to common sense bud, nothing much advice i think can give you apart for just looking about.
IF it's core plugs, is this terminal, or can they be replaced?
If block is pressuizing, the very last thing to go is core plug.
Fun this! 8O
