mk1 1988 Clipper 1.8 Carb Running Issue
(In Topic #94008)
Shortly after this my car started cutting out the same as you described and i still havnt found the problem. What are your symptoms when cutting out?
Has been fine for the last 2 days driving
The temperature has only been like this since the garage "topped" up the coolant
Is this the same symptoms?
Car is going into garge tommorrow so i will keep you posted.
Anyone else have this experience?
Coud a faulty thermostat cause the running problems?
Taking mine to the garage to get them to give it a quick look over
It used to run hot till the garage topped up the coolant ?
Is the Thermostat easy to replace ?
Thanks for all the help peeps
mk1 work in progress
