Mk 1, 1.8 clipper cuts out
(In Topic #83435)
Any help appreciated……
Many thanks,
Craney.
If not there is probably lots of rust/muck/water in it that may be blocking the fuel lines. :dontknow:
or… is the carb pre-heat pipe connected, VWs are reknown for iceing up their carbs in damp weather
or…. a lose electrical connection
or the fuse box has been damaged by water getting into it
or its not unknown for the ignition switch to play up.
When it does stop how long before it will re-start and run OK?
There is no set pattern. It will start again straight away. It's an automatic, so if you keep up the revs, you can drive on the brake!!! not ideal though.
Does it slow down and loose power or just stop dead when it happens :dontknow:
