Mixture and idle settings
(In Topic #79002)
I need to know the base settings for the mixture and idle on a pierburg carb on a 1986 1.6 cabriolet,there is a pull off bung on the top of the airbox is this the mixture?,and where is the idle screw? i don't have a haynes manual,any help appreciated.
Re: Mixture and idle settings
Yes you are correct, remove rubber bung and that is the mixture screw, as regards to other problems finding idle screw i have posted a little bit of info for you in your lastest topic fella :wink:
