Major oil leak
(In Topic #80200)
Major oil leak
Hey there, i was wondering if any1 could help, I have a 1.8 clipper convertable, and it is leaking oil which looks to be coming from the back of the engine. I have replaced the camshaft and the crankshaft seal as advised but it is still leaking. pleassssee hellp :cry:
cheers will replaced, looked underneath the car, and the oil is dripping from the top down and has actually completely covered the rear of the block and underneath the cambelt cover.
Do the big blocks have the oil breather on them? :dontknow: (It's a half tennis ball sized thing with a pipe sticking out the top of it, at the back of the block) If so it might be that, I had one get blocked on a 1.1c and it pissed oil everywhere, good thing is though its a cheap fix, but an absolute pain to fit.
thanks, had a look but can not identify anything like that.
Oil leak
I had a similar issue replaced my rocker top gasket and noticed oil dripping from back of sump, looked like my source was the rocker top it was running out travelling behind the crankshaft cover etc down the back of the engine/sump and dripping from there.
I would check each stud for any oil give them a quick tighten up clean the engine of any oil including back of block and see if you can spot where its coming from after a drive similar to what Chudd said.
Took me a while fingers crossed mine is ok now, just about to make a routine check make sure.
All the best.
All the best.
If your going to change the rocker cover gasget.theres a replacement one piece VW kit (part number 026198025c) you have to change the studs.but should prove to be a better seal than the standard cork ones.oh yeah, and you wont find bits of it in your sump!
1983 lhasa green GTI
1982 lemon yellow CL
