main jet sizes pierburg 2e2
(In Topic #141865)
I got all the parts from the old EW engine (Manifolds, carb, fuel pump, dizzy, flywheel+clutch, …) and blocked up the injector holes on the JH head with 020 gearbox pluggs.
Now im having a bit of trouble rejetting the main jets, ive got it running but i like to know ive got it right. The cars driving beautifully accept when im on low revs and accelerate it seems to struggle a bit to respond, and when i thrash it a bit its a little smokey, (it smells fuelly and oilly). I also get a bit of a bubbling sound from the carb after i turn the engine off. I know the EX engine is a 1.8 with carb, so if anyone has any idea what jet sizes the carb on this engine has, they should be about the right size right?
Please give me a bit of advice as i wouldnt like to wear out my engine due to over fueling.
Thank you guys very much. Ben
026 129 405 - main jet, 1st stage, 105
055 129 405 J - main jet, 2nd stage, 120
027 129 415 - idling jet, 42.5
is that any help at all?
1st stage 112.5
2nd stage 130
idling jet 42.5
The problem was exhaust fumes smell a bit fuelly, spark pluggs are black and when you put your foot down it seems to die a little nd then starts accelerating. Then when you ease off the gas pedal a bit, you would feel a bit more power.
I fitted the 105 nd 120 jets but it seems to be worse, i dont understand as it seemed to be overfueling before.
any other ideas? maybe its not the jets.
I think my valve seals need changing cause it puffs a little cloud of blue smoke out sometimes, would that effect it?
