Lots of questions - perking up a 1.8 auto
(In Topic #170490)
Bearing in mind my daily driver is a modified Corrado VR6 - I'm not expecting miracles but motorway cruising is pretty tedious, particularly with only three ratios. I do like auto boxes (got a dodgy leg) and the acceleration isn't too bad but it's showing its age a little. Would be nice if I could squeeze a little more out… I have average mechanical ability so preferably nothing too drastic.
First question: Is there a four-speed auto box that'd fit? I've got a feeling all the newer ones require loads of electronics and feedback from the engine management (the 096 in my Corrado does), but you never know. I know it's tons of effort to swap to manual so I'd probably only do that if I got really enthusiastic and started planning an engine transplant.
Second question: Can I fit DX performance components to my EX? There seems to be almost no info about them online. Assuming I pick parts designed for solid lifters it's the same but without the fuel injection/ECU, right?
Third question: What should I fiddle with and what should I leave alone? The stock air filter is tiny and breathes through a tiny corrugated snorkel tube snaked around to a clip by the radiator, so that's in my sights - I'd be much happier with a bigger filter and a clear path to the carb. Are any of the aftermarket cams any good? Exhausts?
Thanks in advance
"Klaus": 1987 Clipper Cabrio, LA7Y, 1.8 Weber (auto)
1995 Corrado VR6, LK4Z: RIP
2003 Golf R32, LB5R
2003 Golf R32, LB5R
not sure on the auto ones, the mk3 era ones should fit but dont know if they have any more gears, the only one i know of with brains is the vr6 auto box but that wont fit anyway. mk4 and newer definitely no good.
dont worry about the air inlet, its plenty good enough. a new filter is all you need there. bog std mann ones flow fine, if you must you can fit k&n or similar but they wont gain you anything.
for a decent increase in power fit a gti cam matched to the type of head, solid lifter or hydro. if not sure remove the cam cover and check the caps, if theyre all there its solid if 1 is missing its hydro. Fit a GTI kjet dizzy to match it (with vacuum advance like yours), and a mk1/cab/rocco gti 4-2-1 manifold and downpipe (the ones with the 6 bolt flange rather than the toilet bowl)
if you want to go a step further a gti head will help too. if its got a weber then no need to worry about the coolant channel, just cap the pipe off for it on the metal pipe and you're done. block injector holes either by leaving injectors in, drop coins under the inserts or fit gearbox drain/fill bungs.
What's the difference between the GTI head and the EX one, and how different are the cams? If I'm doing a cam swap I might as well spend some cash and put in a decent aftermarket shaft..?
Stone
2003 Golf R32, LB5R
2003 Golf R32, LB5R
in my book when tuning 8v engines its best to keep it cheep and cheerful, as you could just drop a 16v lump in. bear in mind to get 139bhp out of an 8v you'll have to spend a fair wedge, 1.8 16v has this standard. granted some may prefer the 8v power delivery, but if you dropped a 2.0 16v in you would have best of both worlds loads of low torque and plenty power up high, these start at least 150-160bhp before you even think about spending any money. to get that out of an 8v you would have to drop serious coin!
if you want to stick with the 8v then look at 2.0 bottom ends is a great upgrade and blocks can be had for peanuts these days
Also, how much would I be expecting to find one for? I know all about VR6 bits but the four-pots are still fairly opaque to me
Cheers,
Stone
2003 Golf R32, LB5R
2003 Golf R32, LB5R
i wouldnt pay more than 20-30 posted for a gti cam tbh, theres loads about and you cant give these lumps away anymore as everyone wants abf , vr or 20v lumps these days
2003 Golf R32, LB5R
2003 Golf R32, LB5R
V5 confirms he has an EX engine but the cylinder head is marked 026 103 373Q which the internet says should be on a 1.5 Golf Mk2 Driver
Can't see the cams through the oil filler (there's a plastic splash shield in the way) but I'm now pretty confident it's a hydro head so I'll get a GTi camshaft on order
2003 Golf R32, LB5R
2003 Golf R32, LB5R
2003 Golf R32, LB5R
2003 Golf R32, LB5R
Cheers!
Stone
2003 Golf R32, LB5R
2003 Golf R32, LB5R
Glad I did as they spotted loads of extra bits - two dead wheel bearings, cracked fuel lines and a missing exhaust mount being the main ones, but they also tidied loads of stuff in the bay to put it back how it should be. So now I'm a bit more reassured it's not going to die on me!
The cams make it a much nicer car to drive - it's not a lot quicker but it's perkier under acceleration and the revs rise a lot quicker, especially on kickdown. Much nicer, especially with the rear wheel bearings not being knackered any more. Thanks for the tips
Stone
2003 Golf R32, LB5R
2003 Golf R32, LB5R
