lady in distress please help
(In Topic #77604)
The engine started cutting out last sunday on investigation thought it fuel filter the problem as it was black! changed the filter but engine still doing you seem to be able to drive for approx 10 minute then the engine will cut out stall and you kangaroo to a stop (doesnt matter whether your doing 70 or 20 MPH) it will start straght away but then cuts out again severall times before you can get home. the car has been in and out the garage this week and between then and me weve changed the Fuel filter Ruled out the fuel pump, cleaned the carb, changed the points, condenso,r coil, HT leads cleaned & checked spark plugs.
The garage seem to think theres a loose wire somewhere but have pretty much wiped there hands of the car! Any ideas on where to start looking?
Going away for week tomorrow and think Im gonna have to buy another car when I come back (last resort) if I cant get it sorted.
Please help! :cry:
Yorkshire Region Host
Mk1 Cabriolet 1500 (under resto)
Mk1 GTI
Mk1 GTI
Spent ages trying to find cause of problem to no avail. Even took it to a couple of garages. Both were obsessed it was the ignition system. Looked at/changed coil, points HTs etc with no luck. Not once did did the garages consider the fuel system etc. In the end I sorted the problem myself.
In fact this was one reason why I decided never to pay a garage again to do anything other than an MOT. Unless you find a real good one (do they exist?) many don't have a clue when it it comes to diagnosing anything out of the ordinary. As in your case they will change and charge you for the most obvious bits, then if it doesn't sort the problem, bottle out of it… amatuers :posh: . Most everyday garage mechanic you come across nowdays are simply glorified parts fitters.
You say you had crud in the fuel filter, how old was that filter? Has the new filter dirtied again? If it has, chances are water and various muck is getting onto the fuel tank and blocking the fuel uptake etc. Everytime you stop the engine and the pump stops sucking, all the crap drops back to the bottom of the tank waiting to be sucked up a again. Give the filler neck a thorough inspection, if there is a hole you need new filler neck (worth changing rubber connecting hose frm pipe to tank), new fuel filter and check/clean out fuel tank.
1983 1100 C
1983 1100 C
Mk1 GTI
Mk1 GTI
Thanks for all your help it much appreciated youve helped put my baby back on the road and most definatly the smile back on my face!
Mk1 GTI
Mk1 GTI
fingers crossed, you should be sorted now.
