Lack of Air Filter
(In Topic #76420)
Lack of Air Filter
After opening up the air filter I was bit surprised to find that there was actually no air filter in place to replace!
So I've been driving the car for 3 months without an actual air filter. (yes, you're correct, I'm not the most mechanically minded of people, but I'm getting there)
Will this cause problems for the car in the long-term and would this explain why the car was quite thirsty on trips?
Is there any other things I should be aware of that would be caused by the lack of an air filter??
It would not account for heavy fuel consumption I'm afraid - that may be more to do with your right foot - lol
Air filter
Would the K&N make any real difference to the cars performance?
Life Member
Nothing wrong with the original paper element to be honest! Better to have one than not have a filter though.
Cheers,
Drew.
Once a Mk1 fan, always a Mk1 Fan...
I'll run it for a month and see if there is a noticeable difference. If not I'll stick it on ebay (the filter not the car)
Leaving the airbox standard is also the best move, unless you've modified the engine a lot - admitting hot air from the engine bay just lowers the power output (hot air, less dense, less oxygen, burns less fuel)
