Jittery and splutters. Fuel filter?
(In Topic #141427)
I'm finding that no matter what gear or speed I'm going there is a slight very slight but noticeable jitter or loss of power. Also when I first start her it turns on but I'm having to press the accelerator and rev the engine constantly for about 30 secs to a minute before it will idle normally without cutting out. I'm thinking it is a fuel supply problem but would like confirmation from wiser heads such as you guys. Any advice will be helpfully. Cheers.
hi
1989 MK1 Golf Clipper
1999 Ford Cougar 2.5 v6 (soon the nightmare will be over and car gone)
From my experience if your having to wait 30 seconds feathering the throttle to keep her going. something in that 30 seconds is going from bad to good…this could be Aux air valve stuck or the WUR not adjusting the fuel pressure correctly while warming up.
I also have to feather my throttle for 20 secs or so, but mine doesnt cut out it just idles very lump.. i changed the Wur and it was no different, swapped the aux air valve and now it holds its own idle.
my 2p
<a><img></a>
might be the metering head…might be the ignition side… when did you last service it? Dizzy, Rotor, leads etc?
its atleast drive-able so start with the simple, cheap things and perhaps change the fuel filter…
<a><img></a>
could be carb icing so check the warm air feed is there and the metal shround is still on the exhaust manifold. look at the warm air feed diverter flap too make sure it actually opens.
if its a 2e2 carb read the sticky at the top of this forum
