inlet manifold freeze/core plug size?
(In Topic #154132)
On the drivers side of the inlet manifold are 2 holes about the size of a penny one seems blocked off however the one to the rear lets water out quicker than I can put it in; my limited knowledge says freeze plug but after a 10 min chat with the dealership he says its discontinued. I've had a good look around the Internet but just cannot find out what size its supposed to be.
Am I looking for the right thing? Is it available anywhere? What size is it? Can I just weld a penny in place without blowing myself up?
Cheers in advance and hi all!
Are you sure you don't have a webber carb?
What im looking for is further down on the side of the inlet manifold. Have a pic, ill try figure out how to add pics via my mobilemark1gls said
Pic of webber carb by pass on drivers side of inlet manifold, I don't have any pics of the other side, I'll try and get some of where the water pipes go.
N 011 903 4 - 0.43+VAT
N 011 904 7 - 0.39+VAT
there is a remark on the first one '16' and 2nd '18' I'd assume thats the diameter? doesnt say which is fitted, but the 18mm is listed for mk2 only so id assume thats later part, 16 is early
rubjonny said
your dealer is blind, the parts are still available! I can see 2 listed:
Thank you very much. I'll go back with part numbers. I do have it filled with aluminium putty at the moment which is holding if anyone is stuck in future. I will however be ordering the correct parts today though.
Thank you!
