Inlet manifold coolant blockage
(In Topic #182034)
Any help will be massively appreciated, so I had the cylinder head out today and whilst removing the inlet manifold I found the coolant channel completely blocked by some rubber. It sounds like this is the oring that fails quite often. I'm assuming I just fit a new one (between head and manifold) but all the threads I've found are for peiburg carbs, I have a webber is this port supposed to be blocked or should it be open?
Thanks all
1985 Cabriolet GL
1985 Cabriolet GL
that link is the one you need
1985 Cabriolet GL
