ignition timing
(In Topic #96860)
ignition timing
thanks
My 89 1.8 clipper was reset to that and it goes really well…has Weber also. keep smiling, J.
Beetle restoration. Cabrio GTi (black and shiny). Golf driver.
16v MK2. (Oak green) Now on a Clipper (to keep). Audi A8 4.2 Quattro sport and a BMW R65 bike.
1983 1100 C
1983 1100 C
1983 1100 C
1983 1100 C
according to my mates book (unleaded ignition timing) it needed tio be set at 16 degrees with vacume connected?
had mine set at 16 but it seem's under powered? has anyone tried 2 deg's??
I think a 1.8 carb engine should be 17-19 degrees at 675-825 RPM with vac connected. another 2 takes it back 19-21 degrees BTDC. The smaller engines and the injected versions the vac should be disconnected and plugged. Trouble is …having got one running right, it is a hell of a job to measure what it actually is !
Isn't that advancing the timing (unless I'm still half asleep)? Advancing means the spark happens at an even greater point before TDC. Retarding to 2 degrees would make it 15-17 BTDC, although I had to retard my mk2 carb 1.8 to about 8-10 BTDC.
1983 1100 C
1983 1100 C
Nope, you got it right.
As far as I know, you should only be putting super unleaded into a 1.8 carb engine, due to it being a high compression. Super unleaded is the same (near enough) octane as 4 star, so no timing adjustments are required.
You can use regular unleaded if you don't use all the performance of the car, eg not more than 3/4 throttle, no high speed motorway journeys, keep revs well below maximum.
1983 1100 C
1983 1100 C
My Cabrio has the dealer sticker on the slam panel and I've been looking to find out what the timing should be to put it back to orginal and get my missing horses back.
The two MK11 Golf Haynes manuals I have both quote 17-19 BTDC (doesn't mention vac connected or disconnected).
I have a Haynes databook on CD and that says Golf Cabrio/Scirocco 1.8 1983-93 should be 18+/-1 BTDC at 750+/-50 RPM vacuum connected and for 95 RON 14+/-1 BTDC.
just about takes care of the 2 degrees retarded comment. Don't
forget it needs to be set at idle speed (about 750) rpm.
I think "Early-1800"s post has summed it up. While you're about
it , I would check your distributor advance / retard mechanism and weights and make sure it is all free. If you have a Weber, check that
the secondary throttle is opening properly. J
