Idling high!
(In Topic #108733)
Idling high!
cheers bruce
I take it your running a weber 32/34dmtl?
Undo clip on cable in engine bay, best removing airbox to do it so plenty of clearance.
Get someone to lift the pedal inside car, not forcing it just gently hold it till it stops itself, like i say gently lifting upwards.
Then have someone get the 'E' clip you removed from cable in engine bay and move the black part of cable forwards towards carb so you get slack on cable so it is not pulling on the arm on the carb thus your reving, then fit back E clip.
Once done, if reving still, now you have set the cable you know it is no longer pulling on arm turn the idle screw (located at front right of carb with a spring around it, it has a flat head) anti-clockwise to reduce the revs, Job done
Oh your revs should not be sitting at 1000rpm anyway, 850rom should be, or if you want to be a tight wad and save money at lights, have it ticking over at 600rpm
Pete :wink:
Think manual choke gave it away but there again could be stock with manual conversion……………………………….Now reellllaaaaaxxxxx :wink:novocaine said
must stop assuming people are running the stock carb.
Your learning pettle :wink:loubylou71 said
gently does it eh pete
god i love this forum!
Replacement approx ?3.50
Pete :wink:
Hi Pedders you seem to have a red wire attached to the spring (accelerator). I just done my conversion today. Should I have a similiar wire????Peddersgolf said
Here some pics for you bud, Also make sure your grommet on end on foot pedal isn't perished whilst your at it as this will cause cable hook to come undone inside fella
Pete :wink:
Pete :wink:
