Idle Problem
(In Topic #126378)
Idle Problem
can anyone offer any advice?
Trouble with the carb.
Also with the engine running try rocking the air box from side to side and back and forth, you will have to undo the front airbox bolt to get the movement. This shold show any problem with the carb base gasket as it should stop running or speed up.
Would suggest that you look at the pierburg trouble guide on the big block section as this is full of help and helped me sort out mine when it was playing up.
Also try checking the plugs,dizzy cap,leads and rotar arm as these can add to the problems.
Good luck.
If this is living the dream I would like to know who's dream.
car also idles at about 1000 rpm that about normal for a car of this age?
about 1500?
anyway i can get it down?
where does the number 3 in the diagram go?
I think this is your answer to the carb pipes.
1. Thermo-pneumatic valve
2. Restrictor
3. Straight connection hose
Stage ll vacuum control unit
1 This device is fitted to 1.6 litre manual gearbox models and 1.8 automatic gearbox models from August 1984 on. Its function is to delay the Stage ll opening slightly whilst the coolant temperature is below 18°C. It achieves this by venting the vacuum hose via the thermo-pneumatic valve and the resistor (see illustration).
2 Check that the straight hose at connection 3 on the thermo-pneumatic valve is not blocked and check the valve itself by blowing through it. It should be open at 18°C and close when the temperature rises above 28°C.
quite a novice so its a little too jargony for me
www.salientphotography.co.uk
~Madferret
Mk1 1457cc 5door GX '83
