hydraulic tappets
(In Topic #133837)
hydraulic tappets
RIP
HE TRIED HIS BEST
HE TRIED HIS BEST
this can be done by adding a litre of Dexron II ATF and running the engine up to temp, for a really dirty engine you can run the car for a couple days but only gently, i.e. no ragging it around the place!
then drain the oil and use a genuine vw or a good quality MANN oil filter, the cheapo pattern ones arnt good for hydro tappets. the reason is the proper ones have a non-return valve in which helps keeps the oil in the head and in turn keeps the tappets pumped up.
if all the above fails they can be stripped and cleaned out, but personally i would just replace the set.
RIP
HE TRIED HIS BEST
HE TRIED HIS BEST
RIP
HE TRIED HIS BEST
HE TRIED HIS BEST
