hummer MPG from my 1.5... plz help:D
(In Topic #80701)
Ive done a compression test and its all ok (10 bar), so its not that, the car idles at 1500 with the choke off so that needs doing i know. where is the idle speed screw on th webers?
another strange thing is the revs get lower when you put the choke on, which is something ive never experienced before??
the cars getting about 15-20 MPG if that, so if anyone has any suggestions please come forward
:wink:
Http://www.ihidden.com
That may be due to the carb running far too rich , does it omitt black sooty smoke on idle ? To much fuel and the wrong mixture would cause this .
I would think a good service and tune up would help the consumption figures . I do not have the exact information on how to adjust the Webber but have a troll through http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewforum&f=7 this section and the answer will be there . The automatics were never very economical but yours should give well over 34mpg .
any explanations for the idle dropping when i put the choke on? the car started fine about 1/2 hour ago with no choke, and its damp and cold. i think it could be as its running so rich, then its over chokeing it when i turn it on, causing it to splutter a wee bit :wink: thanks for the help
