How easy is it to replace radiator?
(In Topic #130962)
I'm probably going to buy one from GSF, and am thinking about fitting it myself.
How easy is it to do… have searched threads but cannot find answer.
Thanks.
Before you attempt note how the rad cards are fitted sides and top, take a couple of pics if you want.
If they are shot my want to get new beforehand with new fixing clips.
Id have fresh vw coolent ready so you can put fresh in (pink stuff G??). May even wish to use a hose pipe to flush the system through.
follow the instructions from Zorba.
New radiator wont come with fan temp sender probaby so you will have to unplug that and then transfer that over.
The top brackets that attach rad to body can corrode and expand so give them a clean and if you want put a load of vaseline in the slots they attach to the rad. Will just delay them rusting again. Do an occasional check any white staining could mean youve not got a proper seal on that joint.
1988 1.8 carb Golf Clipper
hella make, good quality
only issue i had was i had to chop one of the rad bracket holes open with a knife as the wrong one was filled in. you'll see what i mean, may even be direct fit as i was putting it in a mk2
