high revving / over run - please help
(In Topic #105958)
I have an 89 clipper cabriolet (carb) which has a problem with idling. A few months ago I took it to have the carb stripped and cleaned but now, when cold (and for the first 10 miles or so) the car idles at around 3000 revs - I need to disengage the clutch almost totally to keep the revs when down when stopped. I have noticed there is a "rod" that comes out when the accelerator is pressed - this seems to stay out at times! - The problem sometimes goes when the car is warm. The car also overuns when I turn the ignition off (and misfires).
Please help…..
It is supposed to rev very high to start with (on some carbs) then decrease in steps, its a feature of the auto-choke system. Not too sure about this car though sorry.
~Madferret
Mk1 1457cc 5door GX '83
The over run and mis fire is down to it running to rich, take the spark plugs out and check the colour of them.
with the rod do you mean the one on the 3/4 point unit? if so then this is likely the issue if its stuck out. as above it should stay out for a bit on a cold start but no more then a few seconds. check the vac lines as mentioned, nice colour coded diagram for em in my guide
also make sure you have ignition live to both of the plugs for the vacuum units on the back of the carb, if not look at fuses 17 and 18 to start with.
if you must root around in my sig look gfor the haynes2e2manual.pdf, but this one is more advanced tuning which should only be done after you have checked everything over as per my normal 2e2 guide
