Hi, can anyone help with my engine running on problem?
Hi, i have just bought a 92 1.8 carb mk1 cab, everytime i turn off the ignition the engine splutters and runs on! can anyone help me with this problem please?  :dontknow:
you need to get your ignition timing checked. too far advanced.
Many thanks first job for tomorrow!  :D will keep you posted.
Hi, can anyone tell me what the correct setting should be? thanks.
Timing and co's bud.
Also no post as regards any mk1 related issues should be in this general section, it's to go into mk1 chat, just letting you b4 mods pick up on it
Pete  :wink:
Re: Hi, can anyone help with my engine running on problem?
What's your engine code?
Hi, sorry bit new to golf's, where do i find the engine number?   :oops: many thanks for the help.
Easiest place to look is on your log book :wink:   Will have 2 letters followed by some numbers, just post up the letters.
Could also be a vacuum hose leaking, carb base block split etc, check em all for splits, especially where they connect.
