Help, Misfire and no power!
(In Topic #131352)
I have a mk1 golf cab with a 1.8 8v engine has recentally developed a missfire. Has recentally had carb rebuilt so could be that but have no idea what needs adjusting.
It has also had new plugs, leads, dizzy cap and rotar arm to try and help but still misfires upto 3000rpm then stops till about 4000 then wont rev any higher..
Hope someone can help need my pride and joy back on the road.
Rich
Sorry if I am being thick I usually ask my friend the stupid questions be he is away lol sorry
Cheers Rich
If it ran fine, then you changed the carb and it no longer ran fine, then I'd say its the mixture not the timing too, but it might have a minor influence on performance if it was slightly out, etc. Maybe worth tweaking once the mixture is done.
Too rich or too lean running can cause a misfire, just as ignition problems can too. Its the same thing - the fuel/air mixture isn't going pop.
