Help i need head swap
(In Topic #75345)
I have been having misfire problems on my, (just back on the road after 6 years) Mk 1 1500 golf. It turns out No3 plug thread is leaking, i have heard helicoil is not a good idea so i am considering swapping my 1500 head for a 1600 head off an engine i have spare on the garage floor. Can i do this without too many problems?
Hi , not sure about the 1.6 head but if its otherwise fine i'd get it helicoiled . Cheaper and you dont need to take the head off , a good garage should be able to do the job with the engine complete . Then if you do have probs later you can look into fitting
the 1.6 head , nothing lost . If you really want to fit the 1.6 head then post a query under modifications , someone on here is bound to have either done it or tried it . Hope that helps .
Racing is life . Anything before or after is just waiting - Steve McQueen
Thanks for that, but i think that it may have been helicoiled in a past life, i will ask around for a good price and i will no doubt be back on with some other probs….cheersgeezer said
What's wrong with chucking a Helicoil down the hole? That's what I'd do…
head problems
hi if it is a jb engine code the 1.6 head should fit the waterways will be in the same location its the 1.8 head that will not fit as im sure the waterways are in a different place
midweekbeatle@gmail.com
full resto on a 80' mk1
abandoned all parts for sale
99' passat 1.9 TDI
99' passat 1.9 TDI
I have a JB engine with a 1,6 head fitted, back in 1984 we had the head skimmed due to a leaking head gasket and got a 1,6 head back.
This has been on the car ever since.
greetz yal
greetz yal
