HELP!! engine suicide
(In Topic #130515)
This is not a good town for psychedelic drugs
do your electrics and everything go all at once?
thats exactly it brucieboy, complete loss of all electricity, its had a new battery, new ignition control module, coil, new plugs, leads, distributor cap and condensor…i think its just lost the will to live i took it to VW and they said "theres nobody here old enough to work without diagnostic equipment" . . . shocking.
are you having to charge the battery before you use the car each time if alternator could have a coil so that its not working to full effect and thus the car becomes reliant more on the battery as you turn on more electrics
if not that a loose conection somewhere
failing that it sounds like what mine did when i bought it home and thats a dodgy earth mine turned out to be the main earth strap covered the ends with soldier and been fine since
hope one of these helps
______________________________
Golf mk1 1.8 gti cab (Still Working on it)
Merc E220
Merc E220
still dying
