HELP!!! cuts out randomly
(In Topic #119005)
sorry for my lengthy drawl but im really struggling and would appreciate any help you can.
cheers in advance, kev
I changed the carb flange, Fuel filter, refurbed the carb with new gaskets etc and new fuel pump. Could be any one of those things and could be many more, like the actual fuel lines from the tank to the carb itself.
Bit of a mine field to be fair
\'83 Lhasa Green GX 1457cc
\'53 Mk4 Golf R32, Deep Pearl Blue
\'00 Kawasaki Ninja J1 ZX6R
\'92 B3 Passat Estate 1.6td (Now breaking) 😭
Today is a good day to die, but tomorrow would be more convenient
I can start it up after a few days, drive it for maybe a mile or two then it just dies and if I can get it to re-start it won't idle, just cuts out pretty much straight after it fires.
MY80 GTI | MY07 GTI | MY10 S3
unless you meant the fuel reservoir on the front of the head, these often get removed on older dubs. no idea exactly why it helps but apparently it does sometimes!
you'll want to get the fuel lines blown thru to check for blockages then fit a new fuel filter and see where that gets you. might have to have the carb off and strip it down to clean out all the crud
resovoir
~Madferret
Mk1 1457cc 5door GX '83
changed the sparks, dizzy cap and arm. ht leads. still had the problem so i went to points and condenser, then the coil… it ran alot better but in stead of cutting right out it was bogging out…
i then moved to fuel…
took off the carb and the rubber gasket it sits on was torn so i got a new one of them, cleaned the inside of the float chamber as things were floating around in there and if there is then thats a bad sign… removed ALL the many different types of jets in the sloex carb and dropped them all into nail varnish remover (thanks mum) stuck it all back together and there we go… all sorted… runs like a minter now…
check your plugs, if they got black soot then its your fuel. if they are ok then its your firing thats the way i looked at it
oh and make sure your battery terminals are done up tight. that doesn't help
like jody said, it can be many problems. all of the above cost me about £60 for all the parts and a weekend in the snow
any way hope that helps
oh forgot to say, mine was a small block 1.1 with solex carb but i think the principle is the same
booze and boredom, the greatest mix
~Madferret
