Help before i put a hammer threw the engine lol
(In Topic #96459)
its now back together and timed up, but now the engine struggles to turn over. which in turn is killing the battery
I timed it up so the bottom marks line up on the inter shaft and crank pulley, and the cam "o/t" mark lines up with the "o/t" mark on the timing cover.
turned it over by hand to make sure nothing hit and then turned over by key and all was fine. but now the plugs are in and the compression is there, it struggles to turn over and will not start
any help will be gratefully recieved before i end up doing summit i regret to teh engine lol
I thought it was timing but just to check, i have lined the timing marks up properly as menioned above haven't i ???
just previous to the head gasket going, i had a garage mess around with my timing as i was getting pre ignition, so am i right in saying i have to move the dizzy back now, is there any marks on the dizzy to where it should be set??
rotor timing marks!
flywheel
cam
time up the engine take cap of and check the rotor arm is pointing to number 1 lead trace the lead back to the plug closest to the cambelt
if all that is ok then do a compression test did you get the head skimmed? just wondering if its been skimmed to far causing major compression over kill :wink:
