Heater matrix gone? Pic included
(In Topic #99472)
Car is a 1600cc carb '85 convertible.
The fan works and seems to get hot fine, but after use theres a puddle that appears in the passenger footwell.
It seems to be a slimy water, doesn't smell and wasn't hot when I checked it after an hours or so drive yesterday.
Is this the sign of a heater matrix failure?
If so, is there anything else worth changing at the same time whilst I have the dash out?
if it doesnt it could just be that water is coming in through the fan and that the drains are blocked on the bulk head.
I would start there.
if first you dont succeed. read the instructions.
The liquid is sticky so I think it's coolant.
Time for a new matrix me thinks!
Found one for ?20 plus I want to change the pipes that run through the bulkhead as their showing signs of wear!
Is it worth replacing anything else at the same time?
Do I need to take the dash out to get to it?
When I worked on mine, I had the dash out anyway. I think it would be too tight to do with the dash in from memory.
