Head gasket failure?
(In Topic #93007)
Well I've had my 1457 (JB) coming up to a fortnight and only had enough time at the weekend to confirm she has spark and petrol getting through.
She turns over fine, but there's no signs of life.
When I took the plugs out, there was fluffy white deposits on 3 and 4, which makes me suspect water.
The car was being driven and was overheating when it gave up the ghost Considerable water loss was going on at the time and I can't see evidence of any leaks.
No emulsion anywhere at all.
I've just done a compression test and the results are:
1: 92PSI/6.4bar
2: 87PSI/6bar
3: 110PSI/7.6bar
4: 84PSI/5.8bar
My Haynes doesn't mention what she should be making, but I'll take a pot-shot that anything below 110 is too low on a worn engine (134k).
Can anyone tell me what she should be making?
Do you think it's conclusive?
Given the overheating, I'm going to presume it's likely the head will need skimming. Head removal looks pretty straightforward - is there anything I should watch out for, given I've done plenty of head gaskets, but not one of these before.
Your thoughts and advice would be very much appreciated.
Gaz
___________________________________________
1983 1.5 5dr GL Auto
1989 Mk2 3dr 16v
1999 Passat 3B Estate 110TDI Auto
1989 Mk2 3dr 16v
Two headbolts were loose and the other eight were nowhere near tight enough. Couple of the water channels were clogged up too (it had neat water in it) which no doubt hasn't helped.
Hope to get it checked for any warping tomorrow and then get it back together
Weather just about held out long enough :roll:
Gaz
1989 Mk2 3dr 16v
1989 Mk2 3dr 16v
HTH
Rich
Gaz
1989 Mk2 3dr 16v
1989 Mk2 3dr 16v
Gaz
1989 Mk2 3dr 16v
1989 Mk2 3dr 16v
Speeding is like masturbation, everyone does it ,but it's not something you should record and put on the internet!!
collo16v said
Are those bores ok? it looks like one of them has picked up?might just be picture!!
I only gave the bores a cursory glance after getting the head off due to the light fading, but they appeared and felt okay. No.4 looks oily coz I squirted it with oil to see if a wet test would throw up anything different (it didn't).
There's obviously a lot of water ingress at No.2 and a bit in No.1. HG looks like it'd blown in several places.
What bit are you looking at? - I'll go take a closer look and photo.
Gaz
1989 Mk2 3dr 16v
1989 Mk2 3dr 16v
I was looking at the rusty one,might just be rust streaks :dontknow:Grumpy said
Gaz
Was blown on 3, if not 4 of the pots Poor little bunny.
It's being skimmed today. Get it back tomorrow. Yi-harrr
Gaz
1989 Mk2 3dr 16v
1989 Mk2 3dr 16v
And after an 11 thou 8O skim:
Would never have seated down without it
Just need to put some time into cleaning the top of the block, then it's back together it goes
Gaz
1989 Mk2 3dr 16v
1989 Mk2 3dr 16v
There's quite a bit of erosion around the water channel in the top right of the photo - how does the block look?
Rich
That erosion corresponds to the cam end bulkhead side of the block in the first photo back on page one. The block looks structurally sound, if rusty in the water channels.
You can see a sludged channel in the first photo and the gasket itself is also blocked in a couple of places. These seem to be shallow 'plugs' of hard sludge rather than deep problematic areas.
Thought i'd remove as much muck as I can manually, then flush and reverse flush the system once the head's back on - but I'd be grateful for any better suggestions!
Had a new water pump not that long ago (might be a story there?), but I'm putting on a new thermostat so will check out the pump at the same time.
Gaz
1989 Mk2 3dr 16v
1989 Mk2 3dr 16v
It's foul outside and getting worse. Definitely living up to my user name today
Gaz
1989 Mk2 3dr 16v
1989 Mk2 3dr 16v
Got the car nose in my somewhat tiddly garage:
And I'm just popping over to Maplin to see what I can do about a brighter lead-light, then I'm going for it.
Gaz
1989 Mk2 3dr 16v
1989 Mk2 3dr 16v
Oh yes 8)
Had to prime the fuel pump, but then she sparked (well okay, spluttered) into life Still got the taste of petrol in my mouth :roll:
Won't tick over yet. Seems to be running warm. Took her for a trip up the by-pass and managed to keep her running at all the junctions :shock:
55mph = 3,000 revs = terrifyingly fast!!
I'm just glad to hear her fire up. Engine sounds all good too
Phew :wink:
Gaz
1989 Mk2 3dr 16v
1989 Mk2 3dr 16v
