Getting Shot of the 1.6 engine!
(In Topic #134461)
I Just want a near on straight swap if possible nothing to complicated, fancy or fast just a nice reliable 1.6 or 1.8.
Its a 1982 mk1 golf GL with pierburg carb on it.
any one got any ideas? or an engine for that matter!?
Help
I doubt if the problems are actually the engine, its much rather the ancillaries or tuning etc. If you replace the engine, it will have same/similar ancillaries, and the same problems, unless you change eg carb to FI. Definitely more details needed please.
basically i got annoyed and just want it out, am i jumping the gun a bit?
I don't know how 'different' than a 1.6 carb you want to fit. 1.8 and 2.0 8V big blocks, on carb, would be a good choice.
Is there much work needed to fit a 1.8 or 2.0?
Don' keep driving the car about whilst head is as it is, your going to make it worse.
Pierburgs are a pain, me personally with all the electronic parts on them i'd be spending money on all sorts of parts and maybe still not cure the issue, so i went over to weber manual carbs on my first vw a scirocco back in the day, wow the memories lol.
no matter what car i bought i put a weber on, never been let down by one as yet.
Do gasket, get a 32/34dmtl weber carb, might aswell get new cambelt and tensioner, do timing and aslong as all other parts, plugs, leads,cap rotor arm, fuel are in good working order or already been replaced, you can have a cracking engine bud.
As mentioned no point getting another engine as it is not just the block that makes you move
Would I still use that weber carb? or is it different for a 1.5 and in that case also do you have any ideas of where to get a cheap carb kit?
For kit try richard aka crazy quiffs on link to left of here or www.fastroadcars.co.uk
Pete
Free to collect from North Herts or its being scrapped soon.
Jon`s Dad
