Fuel Pump
(In Topic #143038)
Fuel Pump
Im replacing the fuel pump tomorrow and was hoping it is as easy as clamping off both fuel lines, removing them, unbolting old pump and slotting in new one?
Is it that easy? I'm not gona get loads of fuel c'mon out of the block am I?!?!
Should get a bit of fuel out what's in the pump. If ignition is off tight it won't pump. Get the new pump on the side after the pump and tightened up, then swap the side before the pump as quick as possible.
MK1 Cabby '90 R.I.P
'83 tin top gti
'83 tin top gti
I can handle that!! Cheers for the tip!
