Exploding oil filter
(In Topic #152382)
89 clipper 1.8 automatic
Got my car serviced at a vw specialists, he tuned it back to factory settings, and carried out a service with parts I supplied sourced from vw heritage.
the car stood idle for a couple of days, once I started it the oil filter exploded on closer inspection the seal had gave way, the garage replaced it and again it happened, this time after I drove for an hour. Again same issue with seal!
Any ideas
Any suggestions how to get into the pressure relief valve and unblock it?
I'd have thought replacement is the best option. It might be possible to soak the old one in solvent or parts cleaner or something, but it might not (fully) work.
Shoukd I try Vw heritage or Avs for the replacement part?
the part the oil filter screws into has no valves in it except the early mk1 gti oil cooler one which has a thermostat in it to close of oil flow when its too cold
Thanks guys
Jon are u suggesting I just replace the whole oil pump assembly?
If pressure is high changing the oil filter housing wont help, unless its blocked internally of course.
edit: theres a nice post about it here with pics and an explanation of how it works:
http://www.clubgti.com/showthread.php?197527-4-cyl-big-block-oil-pumps-how-many-versions-FAQ-added-p2-Updated-p4/page3
looking at it if any crud got into the wrong place it could jam the piston and cause this, he managed to get it out for photos but I dont know if it can be reassembled properly once removed (is the end plate an interference fit, or does it need crimping or something?)
Last edit: by rubjonny
So I decided to replace my oil pump, simply because I don't fancy cleaning out the old one putting it all back together then the oil filter seal goes and I'm covered in the black stuff!!
Anyway removed the sump, and was wondering what gasket should I get for my sump cork or rubber?
the rubber or cork gaskets are for the rocker cover????????
I've just been on GSF web site and they do rubber and cork sump gaskets……… I'll get my coat…….
