Expansion tank replaced - twice - still leaking coolant!
(In Topic #133141)
I replaced my expansion tank a few months ago as I was leaking coolant.
The new tank + cap then started leaking too and was found to be leaking from the cap.
I've bought a new cap + tank and it's still leaking from the cap!
After a run (i.e. engine at full temp) there is a hissing coming from the cap.
However if you turn the tank so that the coolant is covering the cap (i.e. could leak if it wanted to) nothing comes out!? (Engine off)
All I can think of is that the system is slightly over pressurised and when I go round a corner abit of coolant gets out, however over a long trip quite abit comes out and it goes from max to min!
Ideas?
PS: Cylinders were pressure tested at 175-180 PSI IIRC (I was told this was fine, and normal).
Cheers.
Anyone need Air-Con or Refrigeration drop me a line….thats my business! IMG_0245.jpg Photo by jjrobb | Photobucket
So the coolant level when cold should be min, so whats the max point for? When hot?
I will bring it down to the min level and see what happens then!
Jj
Golf MK2 GTI
Golf MK1 CAB 1.5 auto
Member 125 - 2005
mk1jim said
Would be worth flushing the whole system out , and check water pump/ replace the thermostat and fan. Temp sender, sounds like the cap is doing it's job , when engine is on idle with cap off is there a flow of water into the expansion bottle ?
Yep.
It was flushed 6/7 months ago when I replaced a number of hoses and the thermostat and it was pretty much clean (a very small amount of particles at the bottom of the bucket).
Engine temp stays pretty much bang smack in the middle, doesn't overheat etc.
Hopefully it was just me overfilling it, I will see once I use it again!
Cheers Rich
1.8T CABBY
1.8T CABBY
