Engine problem.
(In Topic #145313)
Engine problem.
maybe its carb icing:
http://www.clubgti.com/showthread.php?144497
Remove carb and check carb flange which is rubber and black, unbolt it from manifold via the 4 10mm bolts, check underside and inside the inner rim, for splits, bubbles, causing this will be leaking air.
Or any vac pipe located around the carb :wink:
