Engine getting hot
(In Topic #158424)
Events Manager
Anna
someone say to take the flexie hose off to get more cool are in, is this right, or should it stay there ? thanks for the help
With the fan not running there is a sensor on the right hand side of the radiator (when standing infront of the car looking at the engine) with a elecrical connection on it, unplug it and get a bit of wire to bridge the connection, the fan should run. If it runs its a faulty sensor if not its either a broken wire or the fan is broken.
Events Manager
The wire test is a good one, taught to me by my dad over the telephone when broken down!!
Always keep a bit of wire in the car lol
the warm air feed goes to the pipe on the bottom of the end of the airbox, it runs to a metal shroud around the exhaust manifold. if the shroud has fallen off you'll have to replace it, or just leave it as is. once the warm air feed is in place make sure the vac pipe from the back of the warm air flap vacuum unit is in place, it should run to the sensor in the side of the airbox. the other nipple has a pipe that runs to the back of the carb.
finally make sure the warm air flap actually opens, if its bust you can open it manually to about 3/4 and thread a self tapping screw thru it to hold it there till you find a replacement flap assembly.
as for cooling problem:
http://www.vwgolfmk2.co.uk/viewtopic.php?f=37&t=14913
