drip from pipe....
(In Topic #119074)
drip from pipe....
ran the golf today with new ignition leads and its running like a dream.best for a while!!!
did notice a drip from here………
any ideas what i need to replace/tighten??
thanks as always.
rob
\'83 Lhasa Green GX 1457cc
\'53 Mk4 Golf R32, Deep Pearl Blue
\'00 Kawasaki Ninja J1 ZX6R
\'92 B3 Passat Estate 1.6td (Now breaking) 😭
Not the same as mine so i may well be wrong :?
rob
GSF sells all those bits. if i were you I'd do the flange on the side whilke you're there, maybe give the cooling system a good flush at the same time with a hosepipe and put some nice fresh stuff in.
rubjonny said
thats your dash coolant temp sensor, not clear if its the sensor seal oir the flange causing that, so to be safe I'd buy a new flange and 3 new sensor seals, do the lot
cant thank you enough mate.!
again, invaluable information!!
rob
