daily driver
(In Topic #208594)
Last edit: by Ttwo
You will be better off posting this thread in the right section, try the helllllpppp section?
rubjonny said
if the carb is a bit wobbly you may have a split flange underneath the weber adaptor. Make sure the steady bracket on the front of the rocker cover that holds the front of the airbox is still there and the rubber mount isnt split, without that the carb will wobble about too much and split the new flange pretty quick
Theres a few different types so match the new one to yours.
http://www.ebay.co.uk/itm/VW-GOLF-MK2-1-6-1-8-CARBURETTOR-FLANGE-MOUNT-C81-/200998790091?hash=item2ecc7623cb:g:PBQAAOSwg3FUiFK1
