cutting out
(In Topic #128834)
cutting out
It will start again easily but will only idle with assistant of the throttle as it won't idle on its own.
However.
It generally drives fine just out and about if i drive like my mum with only the occasional cut out. It will give the same symptoms when I drive slowly about but very less often and not so strong.
I have new leads and distributer and in line fuel filter.
Is this a Mixture Problem???
I do have a pieburg 2e2, which, I have to say, have a reputation….
Has anyone ever experienced this or do they have any ideas what is the problem
I looked inside the fuel tank, its clean and silver with very minimal rust inside.
From my understanding it might be either,
fuel pump
coil
amplifier for the coil
vacuum or mixture
Last thing is I recently fitted a 421 manifold and exhaust system does the carb need rejetting for this?????
In essence whats the cause of my problem/s??????
very last thing to try is the mixture, last thing you want to do is try to work around some other issue with your carby
is this fuel pressure i take it. i also noticed that in my fuel supply line there is air bubbles. would this need replacing.
could this be the only cause of the bubbles in the line if its cracked or got a hole or could the bubbles originate from elsewhere.
cheers for the help so far
Does my car have a pump in back around or in the tank. I think it might be called a fuel accumulator i know the later cabs have them but mine usnt a gti so i wasnt sure.
What else could it be
