Crankshaft (front) bolt - Help with removal needed...
(In Topic #82575)
Any tips on how I can prevent this sprocket from turning - if it was held in place I'm sure I could release the bolt - with a 4 foot pole extending the length of the ratchet handle. I don't think that the problem is neccessarily due to the bolt being seized, but more to do with the sprocket turning whilst any slack in the transmission is being taken up!!!???
Any help would be appreciated please - I thought this was going to be an easy job!!??
Thanks.
the socket on the extension against the ground will hold the nut still, and the starter via the flywheel and so via the crank, will turn the crank, and snap the nut free.
works every time
9A,027,278,02A,mikuni r1 carbs,megajolt 36-1,R1 pump,lc1,02J shifter,9J ats…
jamez said
i would imagine that in the last 6 weeks you removed the offending bolt , but the way to do it without the air gun, is to fit the socket to a long handel rachet or extension bar and wedge a bit of wood or similar under it so it points to the front of the car. then with the car in neutral click the start key for half a second.
works every time
Actually no - still not done. Rather embarassingly, on closer inspection, and after a couple of days tring to remove this bolt I realised that the leak wasn't actually coming from there It's coming from somewhere at the rear of the engine - I've not had chance yet to thoroughly clean the engine and inspect - it could be from the rocker cover :dontknow: The oil leak is fairly mild so I have simply been keeping an eye on the oil level and topping up when necessary. Interesting though what you said about wedging a ratchet against the floor and turning the start key - something a local mechanic friend had mentioned. But you won't believe it - it didn't budge it one little bit - tried it about 1/2 a dozen times!!!! couldn't believe it myself but that's certainly the case. I'm beginning to wonder now though whether the car was in gear when I tried ops: Removing the starter and jamming the flywheel also seems like a good idea. Anyway, thanks for the tips guys - job for January I think.
