coolant temp sender
(In Topic #177313)
The red light flashes when your turn the ignition for a few seconds and goes out as normal but the guage never moves.
I guess the first thing to try is a new temp sender but Im confused which one it is?
The black plastic flange coming off the head with two senders in are what exactly?
Im guessing one is a coolant temp sender and I thought the other would be a rad fan switch but the rad has its own switch so what is what? Im confused?
The fan switch is working as it does kick in and out. Just would be nice if the guage worked so I could keep an eye on the temp.
Please help
I will check out the colour or the senders and replace accordingly.
If no change I guess the binnacle is knackered. Will the red light still flash at me if its got too hot or does this only function if the gauge actually moves?
Now fitted and all working again!
Was a bit fiddly as it was the sender on the underside of the flange.
Thanks for the advice!
