Con rod bolts HELP! Over tightened..
(In Topic #144807)
I have tightened the bolts to 30nm stage one. And then 90 degrees and then 90 degrees again.
When I had a read of the vw spec sheet the con rod bolts are only ment to be 90 degrees and not 180 as I have done.
Do you think the 90 degrees over tightening be too much? Or should it be ok?
HELLPPPPPP
