Cold Start Idling
(In Topic #85993)
Cold Start Idling
Carb problem
Sounds like your automatic choke has a fault in some way, if it's the pierburg carb check the auto choke unit on your right hand side of the carb when looking in engine bay.
Let me know how you get on may have a PDF of a service manual I can email to you explains alot more with pictures than I can with words.
Jamie :?
Stuart
2e2
Finally someone else with a 2e2, my 85 cab has one. Mine had a similar problem as yours, got hold of a second hand carb and changed the autochoke unit. Its now alot betta but still got idling problem in that after initial stage once warming up the rev's drop to bout 500 rpm and sometmes dies. I think it's probably down to the wear and tear of certain parts on the carb and settings not being quite right.
Jamie
carbs
They are quite awkward these carbs sorry if I'm causing more problems than solutions.
Cheers anyway
carb problem
Didnt mean anything by last message, my experience is that every carb is individual and every carb has it's individual problems and characteristics.
All the best mate
Ps: I've heard that the rubber gasket is a known issue when worn usually cracks letting air in as you described.
