Chugging Along
(In Topic #113548)
Chugging Along
I was hoping for some help/advice if possible
I've got an 1991 cabby and I use it daily and it runs superb. However when I go for longer drives along motorways it starts to bunny hop along, and loses power. It normally happens if I've been driving at 60mph for about half hour. I drop it down gears as it feels like its going to start firing up again, but doesnt. Once i've pulled over, I switch the engine off, and then back on and it runs superb again….its obviously a worry when your on a busy road and you lose all power!
There appears to be a ticking sound coming from the engine, so a mate suggested to change the HT leads, however this ticking comes and goes. Another mate suggested that I need to change the fuel filter as this could be the cause.
Any ideas/advice would be greatfully recieved, i'm not great at getting my hands dirty but was hoping I maybe able to fix it before I take it to a garage.
Thanks in advance
Sounds fuel related, have you checked your fuel filter? Is it full of rust?
then clean the tank and fuel lines.
the ticking could be a number of things.
thanks for the advice….a mate of mine who knows a lot more about cars than I do also suggested it could be fuel related….I'll give that a go
Thanks again
Andy :y:
worth a check anyway! make sure warm air pipe is there, the metal shroud round the exhaust manifold, and the vac lines to the side of the airbox are hooked up. last of all check the warm air air flap actually lifts when the engine is running
fuel filter is always the 1st thing I change on carbys as its so cheap n easy, if the old one looks to have metal bits & rust in it then its time to check the fuel tank & filter for rust
Cheers again buddy :y:
I changed the fuel filter this morning, the old one was definately knackered! going to take the car out for a long drive later and hopefully I won't lose power! should it feel better to drive automatically or am i imagining things!
Thanks to all for all your help
