Changing the camshaft
(In Topic #143466)
Re: Changing the camshaft
Sibbi said
mines a 1.8 8v..
Clipper (carburettor) or GTI? I am guessing yours is a Clipper, engine code EX, from the way you have phrased the rest of your post.
Check if yours is hydraulic or mechanical tappets - do a search for the difference and how to tell. You can use a GTI or hotter aftermarket cam in a clipper but you'd need to match type eg mech or hyd. And you'd ideally need to re-jet the carb or tweak the FI to get the best from it. This may require a rolling road session.
From my knowlege of the clipper, you can put the fast road cams in with no issues as they are not specific to certain years. As paul said you just need to ensure you run the correct cam/follower combo.
T.B.H your asking the wrong people about doing anything with the clipper, the buy a GTI answer always gets rolled out….. :roll:
This is not really an option for most people!
Anything is possible, depending on budget, I am running a fairly modified engine in my clipper, built up over the last couple of years with bits both new and old, the only cost effective way of doing it, paying out for all new would be madness when considering the pounds to BHP reward.
Fitting a cam in a stock engine would have limited gains, the stock air cleaner and exhaust are very restrictive.
I am pleased with the results from my car so far, despite being told that I wouldn't gain much!
Projekt Frustration :
White 1991 Clipper. Lowered over polished zender rims, Single 40 dellorto on lynx manifold, kent cam, full stainless 'zorst / manifold, powerflex bushed and braced. Not the fastest car, but sounds super nice!
Still going after 12 years… never said it was a quick fix! Time is not my friend.
