Car starts 1st time....then dies!!
(In Topic #136438)
Started it fine drove it home, when i pulled up it seemed a bit lumpy but ticking over normal, next day dropped to around 250rpm revs but still ok and stayed running!
yesterday i started it dropped to 250 and then gradually cut out but started straight away again and revs normal but cuts out. today i revved it at 1000rpm and ticked over around 500rpm, went in engine bay and moved a vaccuum line and ticked over fine so cut it to good hose and put it back and let engine cool. started again 1st time but died straight away!
my engine is a 1.8 carb, hope somebody can shed any light
Bradley
MK1 Cabby '90 R.I.P
'83 tin top gti
'83 tin top gti
Then look in the tank for rust pieces from old filler neck and remove them, also change the in-line fuel filter.
Check the carb flange located under the carb for damage which i think is the cause in this case, then as mentioned check you vac piping.
What carb do you have, can you post pics of your setup please.
Pete.
P.s. i know you may say AND lol, but the rear disc conversion is pointless for a carb model i have to say.
It is mainly for looks alone which is exspensive look.
Reason i say pointless is the weight of the car is thrown forward to the front when breaking thus your best spending on the front setup and make that the best it can be which all you need is 239mm vented disc and gti pads and nice fresh brake fluid.
I know the rear disc is appearance with my engine, i got the calippers quite cheap and discs were on a rear beam i picked up to renew and swap for mine, and when the engine packs up good and proper i will be doing an engine conversion but having lots of service history and me maintaining it with love hopefully will last a while more than 113,000!
Thanks Bradley
MK1 Cabby '90 R.I.P
'83 tin top gti
'83 tin top gti
