CAR STALLING!!! NEW WEBER FITTED.
(In Topic #80284)
Or maybe dirty (large) jets? :dontknow:
Or maybe knackered vacuum pipe to the v.advance?
You will see 2 screw type things, these are the jets in the centre of the weber carb as you look at it from above once you remove the air filter box, get a flat head screw driver and unscrew them, do one first then refit and do the next, simply spray some carb cleaner on the jets or blow down them, there are tiny tiny holes that might be blocked, refit and give it a go.
Just a thought, if new fine, just do the above and makes sure you set the idle at 900rpm once engine is at operation temparture.
The above could be one thing, but if you do it and you have further problems, i'd look at the fuel pump also,
from what you say timing maybe out slighty, also if i remember correctly on the mk2 when i fitted the weber i had to modifiy the vacuum pipes also.
what i will do is i will go round to the garage now and get pics of vacuum pipes locations and post the pics up bud, i'm certain you might have them in wrong places, this would give you problems you are stating.
Hang fire, should have them posted about 11.15pm
Best wishes and i hope all goes well :wink:
You need to buy 2 t-piece vaccum pipe adaptors to fit all pipes, cost you approx ?1 in all
Really hope this helps you bud :wink:
Give it a try.
simon
i always have the last laugh
<a href="
http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg<a href="
http://i79.photobucket.com/albums/j152/mintmaster/part1.jpg
Just try undoing the fuel line to the fuel filter and give it a blow job (ooo-errr!!!). Just blow back on the line that goes back to the fuel tank and see if it unblocks, then take it for a run out to see if that has solved it.
If it does, you may need to clean your tank out and maybe fit a new filler neck if it has not already been done.
Mine still gave symtons like yours long after the filler neck had been changed, just until all the crap came out of the tank.
Hope that helps!
Paul
'89 Clipper
'83 Audi quattro
'89 Clipper
'83 Audi quattro
I`M WITH JBA ON THIS ONE ASWELL, MINE WAS DOING NEARLY EXACTLY WHAT YOURS WAS, AND I SO NEARLY BOUGHT A WEBBER, UNTIL SOME1 ON HERE SUGGESTED LOOKING AT FILLER NECK. I COULD NOT BELIEVE HOW ROTTEN IT ACTUALLY WAS HAVE A LOOK
ANYWAY REPLACED THIS AND GAVE THE CARB A RIGHT GOOD CLEAN OUT AND HAS RUN FINE EVER SINCE.
GOTTA BE WORTH A LOOK EVEN IF IT TURNS OUT TO BE SOME THING ELSE, ITS NOT ALOT OF WORK TAKING FILLER NECK OFF,
HOPE THIS HELPS
THANKS KENNO
But, fuel filter being half full is normal, and fuel disappearing from it on startup is also normal.
That part in the pic you show the link to, is a fuel pressure regulator. These have an internal filter in a 'bowl' (just the shape of the outer casing). Maybe you can see if you can take it apart and check the condition of this filter, as this could be preventing flow :wink:
I think the webers have these as they dont have a fuel return pipe on them already.
Try changing your in line filter first whether it looks dirty or not, and remember to fit it the right way round :wink: As these can become very blocked (not always obviously), not necessarily by rust or dirt, but just from being old and the pump just cant pull the fuel through.
If your fillerneck has caused your tank to be full of rust, you will be able to tell by the amount of crap in this filter!
