car overheating
(In Topic #101694)
car overheating
How long before it overheats?
Is it when under load and does the temp drop when back to idle?
Is there excessive pressure in the system?
Does the coolant smell like the exhaust a bit?
Is the coolant flowing (fan belt, water pump impellor)
Probably one of these:
Thermostat stuck
Blocked radiator
Head gasket
I would try taking the thermostat off first and put it in a saucepan of water and heat it up until it opens. if you have a thermometer even better you can see at what point it opens. If it doesn't open before the water boils then hey presto! Your thermostats broke. If it does then you are probably looking at a more expensive problem.
Tell me about it!
1. Only half feel expansion tank!
2. Fit new water pump if water not circulating.
3. Don,t ignore or cam belt turns to spagetti.
4. If will not restart because to hot then bonnet up bottom pulley give a tug/ move and it will start!
5. Not forgetting the thermostat!
I know this because I have spent a week sorting out
