Car is still cutting out :(
Ok so not sure if anyone has seen my posts but I've been having real issues with my cabby. So fair I've changed the filler pipe, all the pipes, flushed the system. New fuel pump. I took it to a carb specialist today got it bk running like a dream 20 miles down he road it died again.  :banghead: So annoyed i might just put it up for sale I just ant a car I can use not spent a small fortune on and sit and look at it!
Not read posts etc but have you checked for rust in tank, as you've changed filler pipe I'm guessing this was rotten?
MK1 Cabby '90 R.I.P
'83 tin top gti
Yep no rust, tanks as clean as a whistle. The pipe had a very small pin hole but t turned out the filler cap seal had gone.
are you sure its on the fuel side of things ?
maybe silly but do you have correct spark plugs in ?
2000 R1   TOY ;-)
2003 CIVIC TYPE R reliable daily
1989 cabby 1.8 gti  ongoing project (my 1st vw)
husqvarna te 410 supermoto
just aquired a series 1 tintop:D
New leads etc? I had it when getting warm water was getting in dizzy and when warm got condensed and cut the car out.
The water was from expansion hose.
MK1 Cabby '90 R.I.P
'83 tin top gti
I think so, it ran amazing when I got it bk from D&B, I could try swapping them, I've always had issues with my plug leads, I've neve found a king lead long enough!
I'll swap the cap, leads and plugs.
is just cutting out when fan comes on ?
2000 R1   TOY ;-)
Not any more.
so what was wrong?
If you can read this, thank a teacher,
If its in English, thank a soldier.
A soldier fights not because he hates whats in front of him, but because he loves whats behind him.
maybe check the tci unit in the scuttle if its on electronic ignition. its the 7 pin thing bolted to the metal bracket. to check you have electronic ignition or not look at the dizzy, if it has a 3 pin plug its electronic. while you're lookign at dizzy check wires carefully, unplug it and look at the pins inside the plug make sure they're not dirty, bent or pushed back up inside the plug. peel the rubber boot back and check the wires are ok under there.
when you buy ignition parts are you just going to local auto factors and gettign whatever they sell? if so bin it all and buy new plugs, leads, cap and arm from here, all oem quality bosch/beru and will fit properly:
AVS Car Parts - [The VW - Audi - Seat - Skoda Parts Specialist]
check the coil too, make sure its a bosch one. if some cheap rubbish replace it! gsf sell these cheap. check the connections on the coil are the right way round, black to +/15, red/black to -/1.
Look at the connection for the king lead too make sure its the correct type to match the leads. early type have a round hole, leads have liek wings on. late have a pin in the hole, leads have a small round hole with a circlip to clip onto pin. mix these up and it throws spark all to pot
Thanks for this, all parts were bought from eurocarparts. I'll check this out this week.
Did nothing! Anyone in Nottingham no owt bout webers? Or sld I just take it back to D&B?
When it cuts out can you restart it straight away, or do you have to wait?
~Madferret
Mk1 1457cc 5door GX '83
this sounds the same as mine is doing, mine starts up again straight away after its died. It cuts out way before the car gets to full running temp, then when you go to pull away it dies??  :banghead:
It's fixed! Bloody ignition unit.
I got the car running a dream for 200 miles, fitted plugs, leads, dizzy rotar arm all top quality. Coming home tonight it pulled its old trick. Cough splutter and wouldn't rev. I'm wondering if the new carb that's fitted is defective? If so far changed the filler pipe, full fuel flush. Carb re built. New fuel pump. All electrics, all that's lEft to chande is tci unit, I did fit a new one but this made no difference so I took it off, dizzy and coil! I'm a bit sick of this.
hi
i got mine running sweet but some times it starts to juder when on longer drives its doing my box in too.
new coil in the morning see if that helps.
Im changing the coil and fitting a new king lead, ive finally found on the right length.
If this dont work I might break it for spares try and get some of my money back.
not sure if i had same problem but it used to cough and splutter then loose power but did not cut out, cured this by taking return pipe off fuel reservoir or some call it vapour trap, and plugging both ends, now no problem
Haydn
Regional Host South Wales
