Car idles high and overheats.
(In Topic #131048)
Any help and advice would be much appreciated.
Cheers.
Mk1 Golf 1983 1.5 GX
First of all does your fan cut in at all? Is there plenty of water in your expansion tank?
I've had the overheating problem when I first bought my golf, it would over heat in traffic same as yours, It ended up being the rad temp switch on the bottom left of the rad. An easy way to check if your fan circuit is fine is by bridging the connections on the plug that attatches to the switch. (I did this with a split pin). If your fan spins up then you need a new temp switch, fairly cheap from GSF.
Your fast idle fault will probably a setting on the carb maybe? you might be able to adjust the fast idle screw back or something?
Could be timing related too maybe?
06 Audi A3 (Wifes daily)
Cheers very much for the help.
Any signs of coolent leaking, normally leaves a white residue, check top and bottom of radiator and check around pipe connections.
Using any coolent besides boiling over, any signs of oil in the coolent and visa versa?
Does the top hose to the radiator get hot?
Could be head gasket!!
1988 1.8 carb Golf Clipper
