Car doesn't crank but push starts fine
(In Topic #142282)
I drive a 86 1.8 golf mk1, my problem is that my car doesn't crank over even when using jumper leads, when I push start the car it starts fine. I know the timing is out but will this cause the issue I have, or is it something more serious?
The battery is new as well as the starter… :?
Any help would be greatly appreciated!
1982 GOLF GL CABRIO WITH CLIPPER KIT ON BBS RA'S
1996 Toyota Starlet (Wifes )
2007 Focus Ghia TDCi
The fleet stands at:
'90 Clipper
'95 T4 lwb
'94 T4 lwb
'90 Clipper
'95 T4 lwb
'94 T4 lwb
if starter does crank when jumped from the battery then check the ign switch and red/black wire next. plug the red/black spade terminal back into the starter then unplug the ignition switch. bridge the red wire to the red/black wire, if starter cranks its your ignition switch, if not the problem is the red/black wire
